80 rude 50hp info
ob15
Was wondering if anyone could lead me to the right direction to find more info on my motor. 1980 Evinrude 50 hp model #E50ELCSR. I found the basic info but was wondering if there is more detailed info around (i.e gear ratio, weight, etc.) Thanks in advance.
R.Johnson
Re: 80 rude 50hp info
A factory service manual is what you need. It has all the specs. on the entire engine, plus step by step repair procedure.
alcan
Weight W/O tank is 180-187 lbs. depending on shaft length. Tank weight is 11 lbs. Gear ratio is 12:29. There are at least 2 full pages of spects for this motor. You can find them in the factory service manual.
ob15
Thank you very much! I have a manual but it must be a cheapo. It has non of this info.
