motor stars but stops after a few seconds
nigel13
I have an old (probably 70's model) 4hp evinrude 2 stroke. I can get it started pretty easily with the choke out (it doesnt even kick-over with the choke in) but almost instantly it just cuts out. I think it has something to do with the carberator. I got some 'grit' out of there, but it still isnt running. Can you please tell me how to fix this problem. THANKS.<br />Model #- 45B36A<br />M= A0119333
OBJ
Re: motor stars but stops after a few seconds
Hello nigel and welcome to the iboats forums.<br /><br />Sounds what you need to do is get a complete carb kit and rebuild the carb. Your local Johnny/Rude dealer should have them. <br /><br />When it runs with the choke pulled and then stalls out when pushed in is classic plugged jets. <br /><br />Get a service manual for it to. Will save you lots of time wondering about "how-to's". Just remember to hose out the jets and passages real good with carb cleaner and follow up with compressed air.<br /><br />Run into problems....drop us a post.
WillyBWright
You might save a bit of money if you just get the gaskets and a float volve. 95% of the time, that's all you need. But you won't know for sure if that's all you need until you take it apart.
bubbakat
I am not postive of this but I think you have this year motor<br />1975 4506 <br /> 4536 <br /><br />I have a 6 h/p evenrude and did the carb job and it runs well now
bob58
Might want to check the fuel pump diapram while you are at it!
