ekubuckeye
Thread starter- Joined
- Jan 11, 2004
- 15
I would like to check the impellar/water pump on my outboard as I believe it is not cooling properly. I removed the bolts to drop the lower housing and it would not budge even a little. I am sure I got all the bolts but after researching a little I found that I have to remove the forward/reverse linkage so it will drop down. Is this correct? The linkage looks to be permanently riveted or pressed together(I'm looking at the linkage right under the carbs where it decends into the engine). What am I missing/not doing right? Thanks in advanvce.
