91 70 JOHNSON
DLG
MY 91 70 HP JOHNSON ENGINE IS LOCKED IN THE DOWN POSITION AND THE MOTOR FOR THE TRIM AND TILT IS NOT RESPONDING. I KNOW THE MOTOR IS GETTING 12.66 VOLTS TO THE 2 WIRE CONNECTOR GOING TO THE MOTOR SO THE MOTOR IS MOST LIKELY SHOT. MY PROBLEM IS THAT THE MANUAL RELEASE VALVE SCREW HAS BROKE OFF AND I CANNOT GET THE ENGINE UP TO WORK ON IT, IT IS LOCKED DOWN !! ANY SUGGESTIONS ?
Dhadley
Re: 91 70 JOHNSON
Welcome aboard the board!<br /><br />An interesting situation. One possible solution would be to remove the motor and as its hanging from the hoist or laid on the floor, remove the stern brackets. Then you can remove the upper tilt pin and remove the unit for service.<br /><br />Good luck!
DLG
Re: 91 70 JOHNSON
PLEASE TELL ME THERE IS AN EASIER WAY TO GET THE ENGINE TO RELEASE.
cvx35
Re: 91 70 JOHNSON
Use a torch to heat the release....and vicegrips......no, don't do that...you may melt a valve seat or something.......seriously don't..............this is incase that went through your mind :D
JB
Re: 91 70 JOHNSON
Hi, DLG.<br /><br />Please lose the capitals. It is considered shouting on the net.<br /><br />At the risk of destroying your unit you can try to drill out the release screw and move it with an easy out.<br /><br />I prefer DHadley's suggestion.
cvx35
Re: 91 70 JOHNSON
Also, if your t/t motor is shot, when you get the new one, and if it is made of steel, put another coat of paint on it or 2..... also, think of getting some anodes to reduce corrossion......also, if you get some thick wire, and electrical tape the motor wires to it, it's easier to run it through the chinese finger grip thing.....
DLG
Re: 91 70 JOHNSON
Sorry about the shouting, I did not know, thank you for the suggestion, I will drill in and ez-out the screw.
rickdb1boat
Re: 91 70 JOHNSON
Tried that on my 91' 70 HP rude after mine broke off also. Didn't work. Wound up taking it to the dealer and they removed the motor as Dhadley suggested. I don't know exactly how they got it out, but they did. I was sure I'd mess it up worse than it already was. When they are stuck, it's really tough to get them out. Hope yours comes out easier. If you do get it loose and decide to replace it, don't forget to remove the retaining clip around the screw before you try to back it out.
Dhadley
Re: 91 70 JOHNSON
Originally posted by DLG:<br />PLEASE TELL ME THERE IS AN EASIER WAY TO GET THE ENGINE TO RELEASE.
OK. Ya got me. There is an easier way. <br /><br />Let someone else do it.
rodbolt
Re: 91 70 JOHNSON
hello<br /> the easy way is take it to a competent tech. then complain you wuz ripped off by a terbakky chawin bubba:).<br /> that is how its done heah.<br />really there is no easy way. seems PM would have been much ceaper than CM. corrective Maintenance always cost more than preventative. <br /> good luck and keep posting
rickdb1boat
Re: 91 70 JOHNSON
Yeah, I felt that those T&T's were nothing to fool with, unless you've been there before. Hence my trip to the dealer. Cost me about $200.00 to fix mine, but worth every penny. Might have been a bit high, but so are T&T units!
