225hp lower unit oil
85merc200
for my 88 225hp vro outboard engine.<br /><br />what is recommended and what do you guy run...thanks
Hooty
Re: 225hp lower unit oil
Personally? Pennzoil Synthetic.<br /><br />c/6<br />Hooty
85merc200
thanks like the one from westmarine or can i go to an auto part store and buy "gear oil"<br /><br />also can you tell me the viscosity i need i dont have a manual Yet.
LubeDude
Definatly use synthetic! You can buy synthetic automotive gear oil as the synthetics have adaquat antifoaming aditives and protect against moisture, they also will protect your gears better than conventional oil if for some reason you should get moisture in the lower unit!<br /><br />A nice way to install it is to buy a gallon and get a pump that fits the bottle! Buy a rubber nipple for an air blower and fashion a hose from the pump and the nipple, then you can just pump the oil into the lower hole, (Drain) untill it comes out of the top hole! Works very well!<br /><br />Amsoil, Royal Purple, Mobil, Penzoil, Valvoline, Most any of them will be fine!75W-90! or close!
