johnson seahorse 9.9
bobmartin
what would cause only one cylinder to fire?? only getting spark from one coil. replaced coil that was not firing and have the same problem.
OBJ
Re: johnson seahorse 9.9
Bob...welcome to iboats.<br /><br />Can you give us a year or model number please.
Solittle
Bob - First A big WELCOME!!! As to the problem.<br /><br />I would start out by swaping - one at a time - plugs, ignition wires and coils. If that does not do it replace the points & condenser.
bobmartin
the year i"m not certain of. The model number is J10RCTC serial number is E5747726
bubbakat
1983 - CT<br />I think I am right on this model
OBJ
Bob...look for the orange wires coming from the power pack to the ignition coils. The upper wire will be orange with a blue strip. Switch the wires. Top wire to bottom coil and vice versa. Check for spark again. If the situation reverses, the power pack is at fault. Replace it. <br /><br />Keep us posted as to your progress.<br /><br />PS to bubba....ya' count real good :D
bobmartin
I would like to thank everyone for their help. Turned out to be the power pack. Replaced it and motor is doing fine. Thanks to all.
Bearcamp
WOW, did OUTBOARD JIM solve that one........Good job Jim. You nailed it.
