JasonJ
Thread starter- Joined
- Aug 20, 2001
- 4,163
I have since determined that it is in fact a 1956 Johnson 30 hp, model no. RD-18. I spent the day cleaning it. I have no controls, as it is a tiller motor (although controls can be attached). The tiller has been broken off. I also do not have the Johnyrude tank, but I wanted to get it running. I grabbed a cheapy pesticide hand sprayer, the kind you pump up, and ran a hose from it directly to the carb. I dropped the bowl, and the gaskets looked good, there was no junk or varnish in it. I dinked with the two knobs, but since there is no face plate I had no idea what to set them on. After messing with it, I got it running. It ran really well, but since I was not sure what the mix would be, I ran it at 24:1, although I am betting it can run on 50:1 (please let me know). It was really really smoking from the oil. The water pump pumped very well, I left it at a fast idle, problably about 1500 rpm, and I could lay my hand on any part of the engine and the surface was lukewarm. Considering it hasn't ran in at least 5 years if not more, and it is 36 degrees out, it started and ran pretty good. I'll stick new plugs in it, and I think I'll paint it. The gears are good, the lower unit seals looked good, no moisture in the lower unit oil, so for a freebie it is a decent motor. I don't have a compression reading, but considering I am tired, and reached target heart rate pull starting the thing, the compression sure felt good. I'll paint it up and see what I want to do with it after that.
