I have a 2001 150 oceanpro V6. Has thermostats.<br />Two weeks ago I meet Mr. Sandbar( Don't ask, yes I admit it.
). I took it to the guys who I got my boat from,a while back. They checked it out. Found sand all the way up in the Thermostats ( woe is me). So I told them to go ahead and fix it. They claimed they replaced the impeller ,flushed the system and replaced the thermostats( I say claimed cause I'm starting to have doubts. As luck would have it...I went out today( I live is South Fla, so every weekend is a boating weekend) after about 20 minutes into the ride the engine started to heat up. It shot up around 200F. The alarm didn't go off. I saw the temp and backed it down(I was keeping an eye on it cause it was just repaired). Temp went back down to 180. Basically did a little fishing and crawled home. I got home and opened the thermostat. IT HAD SAND!!GRRRR
I called the guy who fixed my boat and said WTF. There shouldn't be any sand in there. He told me that it sometimes gets into the heads and it's hard to get out. THat he would have to remove heads and clean them as well. I smell $$$$ in this guy's head. <br />OK...can I flush my own system and see if I get the sand out myself?? THe telltail has water coming out of it, so it's not blocked or anything. Also...could it be that it had some sand left and it clogged up the thermostat again?? In which case they're probably hosed?? I'm also thinking that maybe this guy didn't replace the old ones and just basically cleaned them up.<br />Any recommendations and procedures would be highly welcomed and appreciated.
<br /><br />By the way...from the looks of this place...you guys have a nice home here. I plan to make it mine for a long time.<br /><br />Always be humble and gracious to the people who let you into their home.
