Shift linkage
bubbakat
I have a problem<br />I ordered me a water pump rebuild for my 1976 85 h/p evenrude and was trying to install it today.<br />I can not for the life of me find where you unhook the shift linkage. My manuel does not cover this any where.<br />I have older johnsons and know where they unhook but can't find this one.<br /> Thanks a bunch guys for an answer
Solittle
Re: Shift linkage
Look just below the carbs on the starboard side of the motor for a fork (linkage to shift lever)with a rod (shift rod)attached to it with either a bolt or pin. It usually takes an extension to a socket wrench if a bolt though some years have a cotter pin to disconnect.
bubbakat
Re: Shift linkage
Thanks so little I saw that and wasn't sure of it but now will proceed with the job<br /><br /> A big thanks
Hooty
Re: Shift linkage
It's cleverly concealed under the lower carburetor.<br /><br />c/6<br />Hooty
seahorse5
Re: Shift linkage
On a '76 with its hydraulically assisted shifting gearcase, you have to loosen or remove the 5/8" headed bolt on the stb. side by the carbs that secures the arms betweeen the shift cable linkage and the gearcase shift rod. A pin is attached to one of the arms and it goes thru the plastic bushing on top of the shift rod. Replace the bushing as it is probably well worn and usually gets damaged during removal. Your best bet is to obtain the correct service manual for your motor.
