1980 50hp wont start , new
phatmanmike
just bought this motorlast week, 2 cylinder model, and finaaly go everything hooked up and motor installed and such. DO NOT HAVE ANY CONTROLS YET OR STARTER. hooked up a battery and rope started it, ran for about 15 secs and died. took starter from my 1969 85hp evinrude and it hooked up and fit 100 %, but now it crnks real easy but wont start at all with this new starter. what gives, its got fuel, its got spark, water is pumping. am i missing somthing, since i have no controls ( i. e, no wire harness) just battery hooked staright in. any help?????
OBJ
Re: 1980 50hp wont start , new
Mike....I'm taking for garanted you have the battery hooked up to the starter solenoid and are jumping the solenoid to crank?<br /><br />What do you know about the motor as far as recent maint.? <br /><br />Try getting a spary bottle with some premix in it and blow some in the carb throats. If it starts, you have a fuel problem.<br /><br />Check the primer solenoid little red handle is straight back along the solenoid and not turned out. This would flood the engine.<br /><br />Check your spark. The spark to each cylinder should jump a 1/2" gap with a hot white spark.<br /><br />Do a compression test just fer grins. The compression on each cylinder should be 10 to 15% of each other.<br /><br />When you say no wire harness, I would assume the large red connector in the engine area has noting connected to it.<br /><br />Keep us posted....thanks.
phatmanmike
i have a "momentary on",red push button switch that i wired to the selanoid, so that when i push it , the starter spins. you wrote, and i qoute"Check the primer solenoid little red handle is straight back along the solenoid and not turned out. This would flood the engine" um, im not getting this ,im slow, what is the primer selanoid?<br /> i have no compression guage as of yet...<br />and yes, the large red connector is unconnected<br /><br />what adverse affects would using this starter on the newer motor have.? starter is from a 1970 85hp v4 and new motor is a 1980 50hp 2 cylinder? it fits perfectly. i dont wanna ruin the engine before spring time comes.....
OBJ
Whoops!! My mistake Mike. Yers don't have a primer solenoid. Just choke plates. Thinking of my 50hp.<br /><br />If the starter fits and is engaging the flywheel gear OK, shouldn't be any adverse affects.<br /><br />Sounds like you have the "push button" OK. <br /><br />JB did a FAQ on "My Motor Won't Start". Real good info there. It's on the main menu of forums, the very first one. Check out the few things I posted and if it still don't start, give JB's post a go.
