Re: 9.5 compression
If you have equal compression on both cylinders, and both read low, I would suspect the guage. I have found a considerable differce in guages, even by the "so called' best of makers. One thing I have never seen addressed is the stem valve in the compression guage. This alone can make a considerable difference in readings as it becomes clogged or dirty. The best test is to pull the cylinder head. I constantly see post's to decarb, clean carbs, sync & link, and etc.Pulling the head is fast, it's cheap, saves time, and money! tells you what you want to know, and only takes a wrench. Yes! I have compression guages, leak down tester, but my best tester is a wrench.
