Re: CLIPPER CIRCUIT
At what point did you replace the stator, and rectifier? Before the voltage surge, or after? The clipper protects the system from voltage spikes. A failed clipper will cause an under charged, or dead battery, even though charging system is good. An inoperative pulse pack. or open or intermittant battery circuit. Will blow main fuse, and fuse continues to blow. You really need a OMC service manual to trouble shoot this system. There is a bench test on that clipper, at my rate, it would take me all night to type them out. In closing, check the lead from the new stator that it is not being rubbed by the flywheel. This is a close fit, and the lead is held down by a clip. Come back with more of what you have done at this point.
