Re: What's inside a 1971 OMC 60 hp amplifier?
To get right to your question, there's been some discussion of the potting materials common in marine 'powerpacks', on the Old Mercs website. There was an extended discussion of pulling the powerpack apart, fixing it, putting it back together, etc.. Should be able to find it by a search there. Personally, I don't know if I'd go far out to sea on a motor I'd fixed myself that way, but I don't have much skill with electronics anyway.<br /><br />A couple other points may be of interest. One, you can run an amp from a 1969-72 V4 on your motor. There are two types on the V4, sensor- and points-triggered, you need an amp from a points-triggered motor (85hp, or 1970/71 100hp), the amp box should be the same shape as yours.<br /><br />Secondly, you're right that you've got a fairly standard ignition design (battery feed, points-triggered with CD amplifier). As you know, cars ran battery/points/coil ignitions for > 50 years. Towards the end of those years, CD ignitions became popular on cars, mostly aftermarket replacement but some direct from the manufacturer. The CD amp is hooked up to 12V, and just uses the points as a signal to fire the capacitor. You get a spark with a faster rise time (if I remember right), and the points have much less current through them. So, can you use an old car CD amplifier? In theory, shouldn't be a problem, assuming it can live in the marine environment. However, in theory you should also be able to easily switch back to a good old battery/points/coil ignition, yet we've had conflicting reports from people who've tried it. You'll need to search the archives here from 2-3 years ago to get to some reports from people who got it working well. I have a old 85hp V4 I plan to try this on at some point, but haven't yet. Should work fine (we're not talking rocket science here).
