I got a 94 225 omc that im not likeing the compression #s on. Motor has about about 20 hrs since rebuild, running fine but #6 is showing about 87 while #1 is about 107. I done the rebuild right i thought with 3 cylinders bored and 3 honed with cooling mods done to the block. Used new Wiesco pistons with new bearings and used but excellent condition rods. I doubled oiled till about 15 hours. I had a hard time getting the motor running right at wot after rebuild but have now solved that issue. Ive sunk alot of money in this motor and want it to be a good reliable motor that will last me a few years. Can I just rering it without honing it back out and get a good job? Also what could some of the problems be for the bad #s. Ive checked the compression 3 or 4 times in the last 4 hours and although it varies some here is about what it is from my memory. #1 105 to 113 #3 103 to 110 #5 97 to 103 #2 96 to 102 #4 96 to 102 #6 85 to 87<br />These are off the top my head but i have exact #s in the garage. Any suggestions on where to go from here.<br />Thanks
