mount bracket for 25 johnson
blueman
there are so many diffrent kind of mount brackets i am not sure with one to get. What am i looking for.
blueman
Re: mount bracket for 25 johnson
a 25 johnson the one on my motor is broken and missing the hold pin and lift spring
OBJ
Are you referring to the transom brackets blueman? These fit over the transom and have large screws to hold the engine onto the transom.
OBJ
OK blueman....if one of the transom brackets is broke, you'll have to look around and find a replacement. Remember there is a port and starboard bracket. You can try a dealer to see if they may have a used one laying around. You can also try the link below. They may be able to help you. One more thing....when posting questions, please include the year of the engine as well as the hp. If you don't know the year, ya' can post the model number.<br /><br />Good Luck.<br /><br /> http://www.twincityoutboards.com/
G DANE
If your motor is 76 or later a complete 35Hp bracket would bolt on too, and its a better bracket, with boltholes for transom.
Johnnielund
Blueman<br />I have a swivel bracket (p/n 328676) and stern bracket (p/n 335713 starbord side p/n 335712 port side). This whole assembly is from a 1990 25 HP Johnson. However the clamp screws (p/n 433675) are missing. Let me know if you can use this assembly. I'll be happy to send it to you.
