76powercat
- Joined
- Feb 21, 2004
- 4
I've got a problem with my 1970 Johnson 115hp v-4.<br />While running at almost full throttle, I had a fuel line burst and cause the motor die suddenly. I repaired the line and the motor started fine, problem is, the motor will push the boat fine up to wake speed and then if you give any more throttle the motor will seem to shift out of gear. The engine will rev up, but the propeller will seem to "free-wheel". Move the throttle back to -N- and then back up and will work up to 5mph.<br />Any ideas where I should start looking?? Thanks.
