I picked up a (very cheap) Johnson from about 1960, pretty sure it's a 7.5 hp.<br /><br />Cleaned out carb, cleaned and set points, primed with bulb on fuel tank line and pulled starter.<br /><br />Fires almost every time, sometimes runs for a few seconds but then needs fuel pumping again before it'll fire.<br /><br />The fuel line from the tank goes to a connector on the baseplate, from there to the carb. Obviously this needs to have fuel running uphill to work!
<br /><br />Is there supposed to be a fuel pump somewhere on the engine that has gone astray on mine? Or do I just hold the tank over my head all the time....<br /><br />Here's a pic of it if it's any help.<br /><br />
