phatmanmike
Thread starter- Joined
- Oct 24, 2003
- 3,869
hello, guys, im back, sorry for the long post, but theres lots to say.<br />6 weeks ago i purchased a used 1980 50hp evinrude from a local dealer/ rebuilder. motor has a 30 day warranty . thats why i bought it from him, ive had bad luck in the past. motor came without starter cause when i picked up motor, starter "went out" as he said. so i got a starter for it myself. then the stator went bad and wouldnt start.it was 3 weeks after picking up motor that i finally got it to start, including 2 trips back to his shop( 86 miles each way). after getting all else fixed, 2 days later number 1 cylinder throws a rod threw my block. so i call him and return motor to be check out as to why. this is what he said...and i qoute"Took motor apart and found the top cylinder ran "Lean". This is a very<br />typical problem if the carbs had NOT been done, but I rebuilt those<br />carbs. My guess would be a problem in the fuel system, most commonly,<br />"Sucking Air". The hoses have "Quick" disconnect fittings on the motor<br />and tank and they commonly leak, or suck air. All the fuel lines on <br />that<br />motor were replaced with new clamps, or Ty-wraps. If a fitting sucks <br />air<br />it will not pump fuel and because of the "T" in the fuel line the <br />bottom<br />cylinder gets fuel, by way of gravity, first. If the system did run<br />short on fuel the top cylinder runs dry first. Any type of blockage can<br />also cause the same problem.<br />I will work with you for a satisfactory closing to this problem,<br />however, it is NOT a warranty issue."<br /><br /> link to his warranty page, please read http://www.vikingmarineservices.homestead.com/Details.html <br /><br />if he did the rebuild himself, how is this not a warranty issue.<br />AM I GETTING SCREWED???????????????????????
