1993 120hp VRO Evinrude, trying to help a friend in need, no compression on #2 piston, removed powerhead, found #2 piston/rings scorched. Rehoned bore, replaced piston and rings, checked others and they were fine. Put it back together, torqued bolts to mfg. spects. After installing flywheel, tried turning crank, wouldn't budge, tore it back down, checked all bolts in right holes, put it back together, crank won't turn. Now what?
