Re: ANOTHER PROP/RPM QUESTION
I would play around with the trim of the motor first. where is the AV plate located in relationship to the keel/bottom of the hull? You might be able to raise it a little. Also, you could adjust the trim a little. IF any of the above can be done, it should be better than getting a new prop. You will gain rpm and speed. With a new prop where the motor is set now will gain rpm but not speed<br /><br />Just my $.02. I'm kinda new here and I'm sure there will be others with more knowledge and great input.
