mechanic scam?
watersparky
I have twin Johnson (carbureted) 175hp Oceanrunners. The mechanic told me all cylinders in both engines have 30 PSI compression; however, the engines start right away and run great. He claims to have used two different gages. Is this possible? What would cause such a reading? Am I being scammed?<br />Thanks.<br />Joseph
snapperbait
Re: mechanic scam?
"engines start right away and run great".. <br /><br /> Ok... What is the problem with the motors? Are they in the shop for something specific like general maint., what? Are you sure he did'nt say 130psi? Is the mechanic wanting to make repairs?<br /> :confused:
JB
Re: mechanic scam?
30 PSI on 12 out of 12 cylinders?? Not very likely.<br /><br />Engines do not break or wear out that way. All cylinders being equal is a sign of a healthy engine.<br /><br />He may have misread something, you may have misunderstood him, or he may be totally incompetent.<br /><br />I think anyone using that claim as a ripoff would be colossally stupid about 2 stroke engines.<br /><br />Ask him to clarify.<br /><br />Good luck. :)
R.Johnson
Re: mechanic scam?
There's something wrong here, both motors' would not likely show 30 lbs. across the board, nor whould they likely show 130 lbs. Engines will not start, and run great with 30 lbs. compression. Did he say what the low, and high reading's were?
Hooty
Re: mechanic scam?
That mechanic's way behind with his BMW payments.<br /><br />c/6<br />Hooty
LubeDude
Re: mechanic scam?
Hooty:<br /><br />Ya, ya got that right, Me too!
DHPMARINE
Re: mechanic scam?
Hey guys. what's up.<br /> Show me an engine that runs on 30 psi,all cylinders and now show me 2 of them.Make sure they are V6's,so we have 12 cylinders running GREAT on all of them? (@30 PSI)<br /> Why are we doing a compression tesr to begin with?<br /><br />DHP
OBJ
Re: mechanic scam?
Nobody seems to know why DHP. Only thing we know so far is lubedude needs to pay off his BMW :D
LubeDude
Re: mechanic scam?
Ya, Im really behind, can I charge $1.00 per post??<br /><br />Really, thats why my wifes car has 275,000 miles on it!
watersparky
Re: mechanic scam?
A guy is interested in buying the boat and wanted the engines compression tested. I had to put the boat back in the water to run it to prove to him that the engines start and run great. I bought a compression gage and start switch last night, so I'm gonna do the test myself. Will keep everyone informed. Thanks for everyone's input. <br />Joseph
jim dozier
Re: mechanic scam?
Hook up a garden hose or do it in the water so you don't damage the water pump while you're testing it. Also ground the plugs wires. Who is running the betting pool on the numbers he ends up with?
Mettaree
Re: mechanic scam?
I'd be willing to bet they wind up 75# or above.<br /><br /> :)
Dhadley
Re: mechanic scam?
Obviously the guy was checking them with 30 lb water pressure gauges and each motor pegs each gauge.
Joe Reeves
Re: mechanic scam?
Have him put the cylinder heads back on, then check the compression again.<br /><br />Seriously..... Have you ever had the feeling that a chain's hanging off your belt and someone's yanking on it?
OBJ
Re: mechanic scam?
ROFLMAO!!!!! at Joe......<br /><br />Put me down for a fiver for 90+psi.
8up
Re: mechanic scam?
Well.......how did we end up? Sorry, I've been out out on travel for a few weeks and I am playing catch up on this message board. This is like a good book with the last page torn out of it.
Joe Reeves
Re: mechanic scam?
WaterSparky made one other post besides the original, promising to keep us up to date. If there was anything added via a different post, I missed it. Anyone else see anything.<br /><br />Really hate it when we're left hanging! Gives one the feeling of "Why Bother"!
Kajun
Re: mechanic scam?
I'll offer 2 bits a piece, for both motors!!!..How did the compression check come out?
