one old johnson
Grahovac
I have an old johnson#513796 #td20 I think it is an 1949 5hp Not sure. need to know what plugs it takes and the best place for parts. The marina<br />says they can get parts for this old of a unit??<br />thanks in advance.
JB
Re: one old johnson
Howdy, BW.<br /><br />The TD-20 was made from 1946 to 1949. All years are essentially identical.<br /><br />Use Champion J6C or J8C plugs, gapped at .030". Use the J8 if you mostly troll, J6 for mostly high speed operation.<br /><br />Gap the points at .020"<br /><br />There are thousands of TD-20 still in regular use, so any JohnnyRude dealer or NAPA Auto Parts Store can get what parts you may need.<br /><br />Good luck. :)
Grahovac
Re: one old johnson
Thanks for the info.The dealer did not have a parts manual that went back that far.The part i am having the most problem with is the springs on the top of the fly wheel for the pull start.Can't find them..
alcan
Re: one old johnson
Hi Big, you might find some of those springs around.The orignal part# is 41,195. If you have one to copy,it may be easier to make your own. With a little trial and error you could supprise yourself.
