115 jhonson long warm up
rhino370
why does it take a while for my engine to run without the fast idle even after its been run and shut off for two hours
Joe Reeves
Re: 115 jhonson long warm up
Rhino.... You don't say what year that 115hp Johnson is, so we don't know if it has a VRO setup or not. However, the possibilities of your problem might be:<br /><br />1 - You removed the thermostat(s), preventing your engine from reaching the proper operating temperature quickly.<br /><br />2 - The valves in the fuel primer bulb might be faulty, which in some cases may allow the fuel to siphon backwards from the engine, causing the engine to run lean until the required fuel is once again suppied to the engine.<br /><br />3 - You're tilting the engine up while in the water fishing, allowing the engine to bounce around with the carburetor floats off level, which in some cases may allow fuel to spill into the carburetor face plate, resulting in a rich mixture when restarting.<br /><br />We'll need more info on exactly what you do, what you encounter, and the year of the engine.
Goodoleboy
Joe....I grabs yar good...! and so is Dehadely...ifin it wouldnt fur you two...I dont know whut we would do. Some of the other guys are purty dang smart bout outboards two....Yall know who I mean...to long uh list tu list em!...Ha..ha!<br /><br />Joe and Dehadely...dont get discouraged..wit some folks that dont post back...The guy that had 30 pounds compression on TWELVE cylinders..no way no how....He was scamin yall..!...jest uh smatelec!<br /><br />Goodoleboy!
OBJ
Hi rhino....if you would post the model number, we can tell ya' what year it is. And as Joe posted, a little more info is needed as to when you last tuned the engine, have you removed the t-stats, is this a new to you boat or a problem that has just started. <br /><br />Thanks for any info you can give.
