1967 evinrude water pump
cblguy4u
Howdy, I got 2 questions. <br /> How much water should come out of the water exaust? and how do i know if it working properly? thanks for your time
cblguy4u
Re: 1967 evinrude water pump
Howdy, I got 2 questions. <br />How much water should come out of the water exaust? and how do i know if it working properly? its a 80hp and the model # is 80753 thanks for your time.
D
DJ
Guest
cblguy4u,<br /><br />At idle you will have a spray out of the exhaust relief port, (about 3/4 way up leg from prop-facing rearward).<br /><br />At planing seeds, the output will be slow stream.<br /><br />If you are worried about overheating, run the engine on the muffs or in a barrel. Touch the top cylinder heads with your fingers. If you can hold your hand there for a few seconds, it's probably OK (145 degrees).<br /><br />If you do not know the history of water pump service, change it.
cblguy4u
thanks for all your help
