Bprice8983
- Joined
- Mar 15, 2004
- 8
I have a 14 ft. Starcraft V-hull with a 15 HP older model Johnson on the back. The motor runs fine, it has recently been re-built, but the boat wont go any faster than around 5 miles an hour, and it definitely won't plane. There are a lot of add-on's to the boat which makes it heavy, but it might be that the shaft on the motor is too short. I know it is a vague question, but any help would be great. If it is a shaft problem, I have another motor with a longer shaft that won't run, is it possible to switch the shafts? <br /><br />I can get serial numbers for motor ID's if it would make any difference.
