GOOD NEWS. . . . The PICTURE UPLOAD FUNCTION IS WORKING !!! The tech folks at the parent company have been able to remedy the issue. You can upload pictures once again. Thank you for your patience.
Is the Johnson tune up stuff in the aeresol can a decarbing substance somewhat like Seafoam? If it is, does it also provide other benefits to the engine?<br />Stalker
A decarb is about all you're gonna get, which, ain't no bad thing. Your TCW-3 pretty well supplies everything else it'll need. <br /><br />c/6<br />Hooty
If you are speaking of the OMC engine tuner,it is indeed a decarb product.It works great and is easy to use.If your engine is equipped with a schrader valve on the primer solenoid under the engine cover ,it is a snap to inject.It puts the "go juice" right where you want it.Into the intake chamber passed the carbs.Just follow the instructions on the can.
