Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
I looked at the tiny tachs website and i want to make sure I ordered the right one. I ordered athe tach model #TT226R-2C(resettable hours). Is this the right one for my 1958 Johnson 10HP QD-19?<br /><br /> http://www.tinytach.com/origigas.html
the tiny tachs work with ANY motor,if memory serves me correct. they simply hook up to your #1 spark plug wire and away you go.. you can even use them on your lawnmowewrs
Yes, it does matter which wire. Top will be # 1. Don't worry, the gauge will come with all the instructions you need. If you are concerned about which one to order, give them a call and they will let you know if it's the right one, but I 'm sure you got the right one..
Hey Kevin,<br /><br />When I ordered mine, I talked to a guy (other than just the phone operator). He was very helpful and explained everything to me. He actually suggested I get a tach that reads 2 sparks and install the wire on both of my plug wires. I have an 80 50 rude 2 cyl. He said it reduces the change of interference from the second wire if I only got the tach that would hook up to one plug wire. Hope that makes sense.
