Johnson 70 hp electrical problem
Ocean Baby
I have a 15' Boston Waler with a 1986 70 hp Johnson engine. The engine was running perfectly at about 4000 rpm's and suddenly stall. It cranks but will not start. I check the spark plugs for any spark but there was none. Any assistance will be highly appreciated.
D
DJ
Guest
Re: Johnson 70 hp electrical problem
Is your kill switch lanyard hooked up?
ob
DJ may be on the right track here.If you have the original side mount controls the safety lanyard switch is held closed with a rubber cap that tends to get stretchd out to the point of the switch button closing (coming out)and grounding the ignition.Check this first before digging deeper into the problem.Remove the cap and have an assistant hold it in firmly while you attempt to start the engine.You may be able to do it yourself.Good luck.
D
DJ
Guest
Good thought OB. I forgot about those danged rubber cap :mad: kill switches.
wellcraft26
Thanks for the reply.<br /><br />Currently I dont have the kill switch connected. My side control is new and is an omc control.<br /><br />thanks again
ob
Yea DJ ,I almost got thrown out of an 83'whaler at wot when one of those caps was causing intermittent contact.Good thing mine was the bench seat model. ;)
ob
Welcraft26,Did OceanBaby post the question for you?If so,by "not connected "do you mean bypassed or just the clip removed.
wellcraft26
No that is my fathers. Is just that I logged in to check something of my yammis and he told me to check his post.
