Pressure Relief valve on '82 55hp 2cyl
jimchere
The motor is an evinrude. Finally, weather is good enough to start spring tune-up!<br />Anyways, I removed the cylinder head cover to check on (and replace) the thermostat. No problem, except when I pulled out the pressure relief valve I forgot which end goes into the head first.<br />The pressure relief plunger is of red plastic, and is a cylindrical device with a flange separating it into two sections, one is longer than the other. I popped the thing out and had a brain fart as to how it was installed. My SELOC manual blown-up powerhead diagram is kinda fuzzy; it appears that the longer section goes into the head, with the short section protruting out towards the cover over which goes the spring.<br />I'm just hoping someone can confirm this so I don't put it in backwards and have to remove the cover again. Also, what kind of sealant, if any, should I use to install the new cylinder head cover gasket (note: this engine has a cylinder head cover, which I have removed. This is not the cylinder head itself, which I have no reason to remove).
Joe Reeves
Re: Pressure Relief valve on '82 55hp 2cyl
One side of that valve should have a slight bevel on it which would face the valve seat.
jimchere
Joe,<br />Thanks for the reply. I looked at the plunger and know what you mean!<br />I'm putting it back together tomorrow with new t-stat and gasket.<br />For the gasket, should I use any type of sealer? By removing the old gasket, it seems a sealer of some sort was used when the last person assembled it.<br />Again, thanks.
Joe Reeves
Use "Gasket Sealer" on the gasket, the type that has a small brush attached to its screw off cap, available at any automotive parts type store.
