1973 6hp no spark on top cylinder
phatmanmike
bottom has spark. top has nothing. checked with timing light and with spark plug. tried new plugs. tried cleaning plugs.<br /><br />all of the ignition is under the fly wheel, which suck, as i have no flywheel remover. does this motor have seperat coils like my 1988 15hp does or do they share a coil like my 1969 85hp does...<br /><br />juts got motor today and this is but one of my probs... thanks
D
DJ
Guest
Re: 1973 6hp no spark on top cylinder
phatmanmike, again,<br /><br />2-colis, under the flywheel.<br /><br />You need a manual....bad!
phatmanmike
already got one :) thanks for the reply
bubbakat
you can get a puller at wally world to do this job for a few bucks<br /><br />There are 2 coils<br /> 2 sets points<br /> 2 condensers<br /><br />under that fly wheel<br />The key to success on the pull is to have the right size bolts to fasten it down with
Paul Moir
And they'd be three 1/4", 20tpi (threads per inch) good quality bolts, about 3" long depending on your puller. :)
bubbakat
Thanks paul I sat here trying to rember the size. Old timmers sett :D ing in
