Re: 1971 Johnson 50HP
Ronnie....just a few things. <br />Get a spray bottle and put some premix in it (gas/oil) Spray a few shots down the throat of the carb and see if it will try and start. If it does, then the problem is fuel which sounds more like the problem than fuel.....I could be wrong on this one.<br /><br />Check the wiring. Some of the wiring on older models tend to get brittle and the insulation starts to fall off. Pop the flywheel and check the coils are not cracked. This could cause them to go to ground causing a "no spark" problem.<br /><br />After setting a few years, it would be a real good idea to change out the water pump impeller. They are rubber and tend to lose their memory and get hard. <br /><br />Remember to only use lower gear lube made for electric shifts such as Bomby Premium Blend. Make sure it says "For Electric Shifts" on the container.<br /><br />It would be real good to go over the fuel system and rebuild the carbs and replace the fuel lines which I would bet are hard and have lost their flex. <br /><br />Once you have her running, give her a good decarb to get rid of any built up carbon in the cylinders and around the rings.<br /><br />As posted before, get a service manual for the engine. OEM's are the preferred manual but for minor maint. work, generics will do.<br /><br />Keep us posted as to your progress.....thanks.
