boatmanwayne
Thread starter- Joined
- May 6, 2002
- 56
Help if you can, I have a 1984 150 V-6 OMC. The engine starts and runs good up to 3100 rpm, then it just loses all fireing, but when you slow down a little it takes off and does just fine, but not over 3100 rpm. I've checked cranking output to the ignition coils per the manual, the readings are slightly low, Does this stator have the low and high speed windings and maybe too weak at higher speeds? I've also checked for grounded or loose wires and can't find any bad signs yet. Maybe someone can steer me in the right direction. Thanks BMW
