Any quick tips on improving engine performance on a 1974 115HP Johnson O/B? I usually live by the motto, "If it ain't broke, don't fix it", but if anyone knows a few quick performance enhancing secrets, I'd like to give them a try!
Is 4500 accurate or is that a guess? We need to know the actual top rpm's with an average load.<br /><br />You dont want to lug a 2 stroke outboard. The increased combustion temp will promote coking and eventually a ring will break.<br /><br />Take a test run with your average load and see what the rpm's are. Its a very good excuse to go boating. If the rpm's are that low maybe we can get you closer with a prop change and a set up improvement.<br /><br />Good luck!If I recall, RPM's about 4500 at WOT.
