Re: 12v -24v conversion
Just go with 8 gage wire and find out the fuse size(ie..10,15,20,30,etc) you need. This should be in the owners manual. I am almost positive that mine has a 30 in it.<br /><br />Like I said above, if the motor is 12 volt and 24 volt you wire it a little different. <br /><br />If it is just straight 24vlt then run the batteries in a series as mention above and thats it.<br /><br />If the motor is just 12 volt you run red to pos. and black to neg.<br /><br />
In any case use 8 guage wire with an inline fuse at the battery.<br /><br /><br />Oh, most 12 volt motors will run on 24 volt current, but they run really fast.
<br />I would NOT use a 24volt system if the motor is not designed for it.
