How to read wake/rooster tail for proper motor setup
Mark42
I have heard a number of times that the shape of wake or rooster tail can indicate if a boat is set up correctly with its trim angle or not. But it was not defined what it is your supposed to look for. <br /><br />Can anyone give some detail on reading wake/rooster tail?<br /><br />Thanks,<br /><br />Mark.
Realgun
Re: How to read wake/rooster tail for proper motor setup
If it looks good leave it alone. :D If you have access to a GPS then you can adjust the motor till you get the best speed on the GPS. Thats what I will do when I ever get my boat near water again.
D
DJ
Guest
No "detail" offered here.<br /><br />In general.<br /><br />A high "airy" wake denotes "overtrim-up".<br /><br />A low "sunken" wake means "undertrim".<br /><br />Most IMPORTANT, what's the boat doing?
umblecumbuz
Hull configuration and individual setup makes a giant difference.<br /><br />Compare rooster tails on fast jetski's with mch more solid wakes on fast boats.<br /><br />Both might do their jobs well, but the wakes are very different - even between two equally fast boats.<br /><br />It's gotta come down to the individual boat and the setup that suits it best. Wake pattern is secondary to that.
Mark42
DOH! I thought it would be simpler than that. Boat seems fine, I was just asking to find out if there were some obvious characteristics of rooster tail that should be avoided or strived for. Actually, I don't spend a lot of time studying my wake pattern.... I'm usually looking forward.<br /><br />This spring I hope to (finally) get some good photos and video of the boat in action. Would be interesting to see what the boat looks like underway, and if I look like a dork at the helm or not! :D :D :D
Buy an inexpensive GPS and search for best speed. When you pass the dork in the other boat the rooster tail will have no bearing on anything and you answered your question. If you can't pass the dork in the other boat, wave politely, smile and tell yourself "I need a bigger motor".
BillP
Ditto...Tweak the motor trim to the gps for best speed. Roostertails are just roostertails.
walleyehed
Now I know why I put a 200+ on a 150 rated boat....I'm the dork that doesn't want to be seen!!! :D
LubeDude
OK, sense I have a roostertasil picture for my avitar, this is what a show-off looks like. :eek: <br /><br />Normally anything much past the cowling of the engine is waisted, not allways, but usually. This was a large diameter prop, so I didnt lose much bite. Wish I had a picture of the whole roostertail, but, you can lead the kid to water, but you cant rely on him taking the picture you asked him to. :D
umblecumbuz
LubeDude<br /><br />You got that 'took it at the wrong moment' type helper too?<br /><br />I've got loads of pics of ruffled water! The boat's long gone when my able assistant presses the shutter! <br /><br />Gotta system now. She's got a motor-drive camera, we use walkie-talkies, I shout at the right moment, and she uses a whole film to get the one shot. Mind you, we've only been trying it for one whole season. Give us time.
CalicoKid
A general rule of thumb I use with fast outboards is that they are running best at WOT if the rooster is about as high as the top of the motor.
Mark42
Oh. I see. My "rooster tail" is more of a "rooster ripple". This is what mine looks like doing about 15mph before making trim adjustments and bigger pitch prop. As you can see, it does not extend up at all. I got the impression that there was something about its shape, or the V shape cut in the water that would indicate efficiency or lack of even if your not doing 80 mph.<br /><br />I guess I done went and embarrassed my self.....<br /><br />
umblecumbuz
Mark,<br /><br />That is one lovely little boat.<br /><br />Shame about the rooster tail!
walleyehed
Mark42, need to add some 1-1/2" wire loom around those exposed battery leads...afore the sun gets'em.
Mark42
Walleyehed,<br /><br />That pic is from before I was done working on the boat. See all the duct tape sealing the splashwell to the transom? Lots more that you can't see. <br />I have an old wrap for the wires, but am thinking about buying some of the newer stuff like you see in cars. Can I get it at an auto parts shop or do I need something special for outdoor use? <br /><br />Mark
Mark42
Stillfishin,<br /><br />When I said "As you can see, it does not extend up at all." I meant the water. :D
walleyehed
Mark, some auto parts facilities have the "UV" resistant loom. Mine is going on 4 years now with no problem. (black in color)
Canuck 16
I believe Bennett trim tabs website has some info on what your wake should look like, and where it should be leaving the side of the hull, when properly trimed.<br /><br />Cheers... Canuck 16
skiffer
Generally speaking, the less wake the better. Water being thrown around, whether from the hull moving through the water or the motor, indicates energy loss.
Frankhanhart
Mark, I know you were thinking of T&T instead of the tiltassist you've got now. Thinking ahead aren't you :D <br />Frank
