Re: Prop Selection
Without a tach, I won't make any recommendation for props, SS or other-wise because we have no Idea what you are turning now.<br />A tachometer is the most important instrument you can have in your boat.....the speedo is a just a result of the works efficiency-not needed for this case.<br />If your mech. told you to lower your engine, I'd like to know what prop you have now (P/N, 214?), where the cav. plate is in refference to the bottom of boat.<br />I find it almost unbelievable to pick up 7MPH by lowering the engine, unless it was being over-reved EXTREMELY before lowering the engine...it wasn't the SS prop the gained the speed, which brings me to the question of speedo type??
