last weekend i unloaded my boat and left it idling at the dock while i parked the truck, to let it warm up a little.at an idle towards the end of the no wake zone a solid horn sounded so i thought it was hot. i pulled the cover and i could touch the heads all day long. i figure its the low fuel warning so i pumped the ball and started it. a few seconds later the horn quit. i took off hit about 4500RPMS and it was like the key turns on and off every few seconds ,if you accel slow it will get up around 5000 . i looked around at hoses and the VRO and there wasnt any kinks or leaks that i could tell. i know its bad if its running lean but i had to get the fill for what it was doing. its an 89 200 evinrude,problem sure fills like an ignition problem.any ideas THANKS
