OBJ
- Joined
- Dec 27, 2002
- 10,161
A fellow brought in a 90' 150XP. This is what he told me:<br /><br />"I was hooking up the battery and when I touched the ground cable to the battery I got a spark. So I hooked it up anyways. The wire from the Reg/Rec to the solenoid started smoking. So I disconnected the battery. Can you look at it and see whats' wrong?"<br /><br />Being the terrific fellow that I am, I said sure. Popped the hood and gazed under the flywheel to see mounds of goo (hard by now) laying under the flywheel area from the mother of all melt downs. The charging wire to the solenoid was fried. This is a 35amp system.<br /><br />Replaced the stator and Reg/Rec. Time for spark test. NO spark. What a surprise. Test the output from the timer base and got zippo. Nada. Nothing on any one of the timer base wires. Retested just to make sure with the same results. Got one on order to replace. The pack is probably gone to but won't know till I get the timer base in place.<br /><br />Question is....I know the stator took a super size shot of juice from the battery. Probably been melting down for a while. Could this have effected the timer base? I know anything is possible. Could the shot have backed up through the pack and made it's way to the timer base? This is a new one for me guys so be kind.....pleeeeeaaaassseeee!
