Re: PM on 2000 Johnson 200
OBJ....Thanks for the info. I think I may have a wiring problem with my alarm, the low oil sensor turns the alarm on constant, like the overheat alarm is supposed to be. I found this out on the water last season when my resevoir went low and the constant warning came on, I was going full throttle and thought I was overheating, when I stopped, the motor was cool and the water pressure gauge was showing good pressure, I looked at the oil resevoir and it was only about 1/4 full, I kept going and it went off for a minute and then came back until I put oil in it. Gotta try and figure that out. <br />Anyway, how do identify the recirc lines in order to follow them back to the intake manifold, not really sure what they look like. Also is it alright to use carb cleaner to shoot through the valves and clean them out or does it have to be alcohol, and what is and where can I find "gel seal", can I use silicone to seal the threads? Thanks alot, sorry for the dumb questions just want to get it right the first time so I don't have to do it again and I'll know it from now on.
