James Akers
- Joined
- Feb 17, 2004
- 22
Let me start with the motors history
<br />Its a 1972 Johnson 25 hp<br />When I bought the pontoon that is sets on, the owner showed me a receipt for some work that had been done last fall by a marine mechanic that I am familiar with, and he is reputable.<br />He replaced points, plugs, condenser, and the water pump. He also charged the guy for checked out coils OK<br />I was a little suspicious of the water pump replacement, so when I got the boat to the driveway, I had bad compression on one cylinder and water seeping from the head. <br />So
I pulled the head, cleaned it up, checked for trueness, installed a new head gasket, and fired her up --- perfect compression 132 top and 132 bottom. <br />By the way
the gas was nasty, so I rinsed the tank out with fresh gas, replaced the fuel line and squeeze bulb, and installed an in-line fuel filter.<br />It ran like a dream, so we put her in the water. <br />After a couple of days, it began to miss, spit and sputter, so I took the carburetor off, washed it out with two cans of carb cleaner, blew it out good the air compressor, and put it back on the boat. I found a small bit of something hanging on the low speed jet needle valve when I pulled it out.<br />It has a fixed high speed jet and an adjustable low speed jet.<br />I got it running great as per carb adjustment courtesy of Joe Reeves instructions.<br />Now my unsolved mystery begins
<br />Next day, I fired it up and it ran like a dream on the pier. I took off at an amazingly smooth idle, and ran for almost 20 minutes at this idle with no shake, no miss, no sneeze like a sewin machine. When I increased engine speed to a fast idle, it ran well for about 20 seconds, and then it was (and is) like I lose a cylinder. When I open it up WOT it clears right up. When I slow it back down to a fast idle, it begins to miss again. I can idle it all day long without any mishap, and I can run it WOT without any problems. But anything in between, I loose a cylinder, spits, sputters, then I get it back for a few seconds, only to lose it again. I checked the timing advance, it seems to be working very smoothly. <br />Any ideas?
