GOOD NEWS. . . . The PICTURE UPLOAD FUNCTION IS WORKING !!! The tech folks at the parent company have been able to remedy the issue. You can upload pictures once again. Thank you for your patience.
Seems that a seal is gone on the front mount of my sea Star teleflex 1.7 6.9amps 1000psi max.<br />part #Hc5345<br /><br />My 1st question is: Can I replace the seal or do I need to replace the front mount???<br /><br />2nd question: If I have to replace it do I need to put a block under motor so that it doesn't drop when I pull the rod out???<br /><br />Thank you !!!!
