willisballs
- Joined
- Apr 7, 2004
- 29
With an older model boat 18' and 1976 Envinrude 135hp....Running the boat at higher speeds for about 8-20 minutes seems to cause the engine to overheat....does this have to do with thermocouples, thermostat, or just running it too high.... ALso, (stupid question) but your not supposed to run at full throttle ever, are you?....Last question...if the motor where to overheat,and the alarm is not working and the temp gauge, does this model have an automatic cut-off switch before it reaches a "damage zone" <br />inside the engine?....THanks for your help,,,,
