Re: 1973 65/hp/evinrude have to choke everytime
LOL!!! Spike, if I had a nickel for everytime I wanted to beat an engine with a bat....I'd be well ahead.<br /><br />Sounds like a fuel flow problem. Check some stuff here. First, check the primer bulb. Make sure it pumps up snug. If it don't, may have a bad valve in it and needs replaced. Sometimes these things will pump up, but when you stop, the valve closest to the tank will let the gas in the line return to the tank.<br /><br />If that's ok, check the fuel lines. Make sure they are all nice and flexible....not hard. Hard lines lose their grip.<br /><br />Make sure the little mesh striner at the fuel pump intake is clean and the gasket is good.<br /><br />Do you know the last time the carbs were overhauled? If the bowl gaskets are black and not a reddish brown, would be a good idea to do this. Soak the carbs out and blow out the passages with carb cleaner and follow up with air. Remove the jets and make sure they ain't got any pluggage.<br /><br />Well...let's start here. Let us know if any of the above has been done or has been checked already.<br /><br />Don't use the bat yet!! The guys here on the forum cry when they see outboard abuse....:-(
