Proper lower unit oil for 1973 135hp
paperdesk
The manuel says to use some special oil that I don't see in any shops around my area. However I picked up some Pnnzoil Marine High Viscosity Lower Unit Gear Lube. SAE 80w-90. API GL-5 performance.<br /><br />Will this work?<br /><br />Thanks
ob
Re: Proper lower unit oil for 1973 135hp
As long as your engine doesn't have electric shifting lower unit it will.
paperdesk
Hey OB, how can I know if it has electric shift or not? I have to admit I don't know the difference yet.
OBJ
Don't think it is Ted. 72' I think was the last year for electric shifts. Yours had a shift assist cylinder in which took place of he solenoids for electric shifts. The Penzoil stuff otta' do.
paperdesk
OK! Thank you for the answers. I'll put it in now. I'm doing a general lube to get ready for the season.<br /><br />Ted
ob
If I'm not mistaken the hydraulic shift assist lower units took premium blend or Type C lubricant.Perhaps someone can clarify.
paperdesk
Yes, it calls for Type C but what is that?
ob
In short ,type C is a thinner less viscous lube.A hydraulic assist lower gear case has an oil pump unlike a straight mechanical shift.I personally just can't confirm which type of gearcase your engine is fitted with,but I know that running the wrong lube is going to lead to problems.
SCO
I have the same motor and use the standard stuff for lower units from academy. Works fine so far( approx 3 years). Mine is entirely mechanical. I think the original callout is for hypoid 90 wt. You should be fine if manual shift. My johnson service manual doesnt say anything about a hydraulic shift for 73 to my recollection. I'll check the manual this eve. I think the electric shift would be obvious.Do they have a special control box w/o the mechanical linkages? I can shift mine without the battery being connected.
paperdesk
It seems to me that it's just mechanical, but I really don't know for sure. I'll be interested to hear what you find SCO.
SCO
Since OB was able to predict the type c oil, I will probably be found mistaken. We need to check the motor serial number to be sure of the year and model might have the info we need. I'll post my info tonight.
ezeke
I doubt it SCO, I've run mine (1973 135HP Evinrude) on high vis oil for years. The original service manual said Sealube, not "C".
D
DJ
Guest
If there are two cables (throttle and gear shift) running from the control box to the engine, it's a Powershift II. <br /><br />Hi Vis.
ob
Here's a quote I found on a search from Mr. Joe Reeves.I can't be sure of what type lower unit is incorporated in your engines lower unit without knowing more info.To recommend otherwise would be careless on my part.<br /><br /> Electramatic/Selectric shift=Premium - Hydro Electric shift=Premium - Shift Assist=Premium - Mechanical Shift (all)=Hi-Vis.<br /><br />Bottom line is that Premium blend is required on the OMC lower units that incorporate a oil pump, or on the early model straight electric shift (Electramatic/Selectric) units.<br /><br />--------------------<br />Joe (30+ Years With OMC)
R.Johnson
The 1973, 135 is a manual shift with hydraulic assist, Hi-Vis is the proper lube, the newer HPF will also work.
SCO
Got some answers. My service manual is for model 135ESL73. There is only one geartrain exploded diagram, it s called power shift II. The call out for lube is OMC sea lube gearcase lubricant and says also"previously OMC type c lubricant". In looking at the exploded diagram, I compared with a CLymers manual because Clymers has a diagram for a "Mechanical " and another diagram for a "hydro-mechanical" gearcase. THe 135esl73 is clearly a Hydro-mechanical type gearcase primarily because it has a gear type oil pump, while the purely mechanical doesnt have the oil pump. So, I also now have the question of what modern brand product should I be using in the lower unit? Again, have been using high vis with no problems for 3 years. It is one great running motor.
ob
Interesting bit of info SCO and does leave one with a bit uncertainty as to the recommended lubricant on the engine in question.Hi-Vis obviously has caused no problems on the gear oil pump in your case.Just wonder if it has had any effect on the operation of the shift assist feature ,baring in mind that it is just an assist to the shifting linkage.I'm not even clear on the viscosity difference from Hi-Vis to type C lube.
