Long time reader, 1st time poster. What a great forum this is!!! The way you pro's help us neophytes is truly amazing.. Thanx in advance<br />Had my Pontoon out on the lake today. Powered by a 98 50 HP Johnson 2 cylinder. Cruising along all day at 5200 RPM's smooth as silk when all of a sudden, felt like a hiccup and motor started to shimmy and shake pretty violently. Immediately backed throttle to idle and it smoothed right out. Turned off motor and raised it to check prop and skeg even tho I knew i was cruising in 40+ feet of water. Everything fine on drive line. Restarted motor and slowly inched throttle up. Fine at 1000 RPM, still good at 2000, right about 2800 it starts with the shaking. Any ideas what happened here? Seems to be a miss of some sort, but clear out of the blue like that? Any help is most appreciated.
