Took my 70hp Johnson out the other day to do some testing of the tach, and the tack failed, but motor ran fine...35 mph. Ordered a new tach, waiting to get it so I can install it. Another problem occured...decided to drain lower unit that I rebuilt...MILKY WATER!! Ran the motor about 15 miles total with new oil in lower unit. I did a pressure test with a hand tire pump. Filled a plastic tub over the first joint of the lower unit. Had a good seal on the pump cuz it didn't "bubble" at the connections. (drained oil, put screw in lower hole, attached hose to upper screw hole) It didn't bubble up any where else either!?! All new seals installed. Drive shaft, and prop shaft looked good too, no wear on either shaft. No metal on the lower magnet screw. Where could the water be coming from? I got this motor for nothin, and all the rebuilt parts too! It's a great running motor, but the water in the lower unit really puzzle's me. HELP!!! TIA Dan
