expertsetup
- Joined
- May 9, 2004
- 8
Hello everyone,<br />I have to say that this web site has been quite a resource for me already. This friday I purchased a secondhand 1959 P-17 16'2" Motorboat Distributing Co. deep V hull fishing boat with a 1971 50hp Evinrude Lark. This is my first boat and I can't tell you how excited I am about this project.<br /><br />After getting the boat home I tried to fire her up. No luck so I started some basic diag. here is what I came up with:<br />Comp: #1 125 psi #2 110 psi<br />Spark on both up to 1/2" blue arc both coils<br />about 4 gears on the fly wheel have damadge where the starter contacts.<br />Fuel lines hard and clamps wire-spring type<br /><br />I replaced all the fule lines and all the spring hose clips with hose clamps. pulled the carbs and B-12 Chemtooled them and reassembled.<br />Motor now starts and runs strong with the muffs but idles high and wont go very far below start on the remote.<br /><br />Since I had it running and the battery ran low I also recharged my battery and took a read before and after the motor was running. no rise in voltage at all. At this point I am not sure where the fault lies but suspect it may be the rectifier. <br /><br />With a unknown fault in the ignition/charging system I am a bit reluctant to run the boat in the water. I am also a bit reluctant to shell out $$$ if I dont have to. I have purchased a parts manual and have ordered the oem manual for this unit. I should be able to determin the fault with the data in the manual (wish me luck). The boat has no Tach and the Speedo looks like it will not function. I can order a tac from TinyTach but will that be O.K? If I have my nice battery for the lights etc. and a starter battery with a good sized solar battery minder would it be safe to run like this? <br /><br />Also for the people who keep stats on this 50hp HydroShif unit. This unit is shifting forward, nutral and reverse. Yes the unit seems to be at rest in forward gear but when cranking it shifts fine.<br /><br />I hope everyone can feel the glow of my gratitude. The FAQ was a huge help and the search function was a big help.<br /><br />Any input welcome.
