imported_salty_dawg
Thread starter- Joined
- May 9, 2004
- 9
Hi guys, 1st post, great bb! Have spent last hour looking, unable to find my problem on old post. I have a '87 Johnson 150(Mod.# J150TXCDC, Ser.# J7157506)I bought recently w/VRO already removed. I get an alarm goes beepbeepbeep for a few minutes shortly after cranking engine, then goes (fades) away, usually when I bump up throttle to run at speed. Problem is, it's an intermittent thing, doesn't happen every time I crank up. Heads don't have time to even reach op temp, are not hot to touch, temp gauge I installed reads 120 or so. New thermostats, pump, etc., so I don't think it's an overheat issue. Also, it's not a steady scream like you usually get from a hot warning. I don't know if VRO removal was done right, from what I've read so far it appears to be plugged right, etc.. Oil mix is 50:1, fuel lines sized right, through water separator filter to engine. Do any of you have any ideas on this one? Thanks in advance...
