foxjohnc03
Thread starter- Joined
- Jun 30, 2003
- 79
My 71 Rude 40 is not running right and has a miss at idle which I believe is caused by a gummed up carb. I am going to take it off and clean it up but have a few questions before doing so. The carb has no high speed rich-lean adjustment, right? The plate on the front of the carb has the writing on it but there is just a hole. Also, what is the correct # of turns for the low speed mixture? I know that you have to tweak it but there has to be somewhere close that I can set it to get it running. Also on the carb bowl there is an adjustment screw. What does it do? I have no clue. Thanks a million.
