fishhawk16
Thread starter- Joined
- May 13, 2004
- 73
I'm looking at this used motor. I was told they are very good and reliable.<br /><br />However when I started to inspect the lower unit I noticed a good sized dent on the front of the gear casing. The dent is about 1/4" deep and about 1 1/2" long.<br />Both props that come with the motor have some damage, not huge amounts but looks like they both hit some rocks and need a little bit of rework. One of them has a small chunk out of it (both are aluminum).<br /><br />Should I be concerned with this type of damage? Is it possible that the shaft is bent? How can I easily check for a bent shaft. I did the spinning the prop trick but it is really difficult to tell.
